ELEMNT RIVAL
RUNNING WATCH
ELEMNT RIVAL creates a seamless training and racing experience for runners. Powered by proven ELEMNT technology to provide a simple user experience to set up and customize the device to fit your lifestyle. With optical heart rate, barometric altimeter, ceramic bezel and water resistance up to 50m, ELEMNT RIVAL is your next GPS watch for running.
JETZT KAUFENJim Walmsley - Western States 100 Champion
NIEMALS DEN FOKUS VERLIEREN
ELEMNT RIVAL uses the intuitive ELEMNT OS to make the setup, customization and user experience of this GPS sport watch simple and seamless. Featuring a durable ceramic bezel, RIVAL boasts accurate GPS to track and record your runs, whether on the track, road or trails.
SIMPLE TO TRACK
With powerful and intelligent running features, ELEMNT RIVAL tracks time and workout data with minimal interaction between you and your watch, letting you concentrate on the task at hand – your training and race-day performance.
JETZT KAUFEN
OPTISCHE HERZFREQUENZ-MESSUNG
Check your heart rate and calorie data at a glance with ELEMNT RIVAL's built in optical heart rate. Set your zones in the ELEMNT Companion App to keep a pulse on your efforts.
GEPLANTE TRAININGSEINHEITEN
Sync your TrainingPeaks calendar or choose one of our pre-loaded Wahoo Sports Science workouts to execute on RIVAL. As you run, interval prompts and target tracking are built into your sessions to keep you on pace.
BAHN LAUFPROFIL
Use RIVAL's tracking running feature to snap to the nearest 100m distance on any standard 400m track to ensure your workout data is as accurate as possible.
WORK REST TIMER
Build out the intervals to fit your training. Create set periods for work and rest time and get prompted notifications during your workout to stay on track.
Simple to see
Mit einem großen Farbdisplay, das einen Umgebungslichtsensor und Perfect View Zoom™ verwendet, funktioniert ELEMNT RIVAL in jeder Lichtsituation, um Ihre wichtigsten Trainingsdaten schnell im Blick zu haben.
JETZT KAUFEN
UMGEBUNGSLICHTSENSOR
Der Ambient Light Sensor von ELEMNT RIVAL hält Ihre Workout-Daten in Sichtweite, auch wenn die Bedingungen alles andere als ideal sind.
FOKUSSIERUNG AUF
IHRE ZIELE
Mit Perfect View Zoom™ können Sie die spezifischen Trainingsdaten DER ELEMNT RIVAL Smartwatch vergrößern und verkleinern, damit Sie die wichtigsten Messdaten problemlos ablesen können.
Super klar
Das Display von ELEMNT RIVAL besteht aus Gorilla-Glas – einer äußerst widerstandsfähigen Oberfläche, die sicherstellt, dass Ihre Uhr so robust ist wie Ihre Trainingsroutine.
FARBLICHE OPTIONEN
Die Auflösung von 240 x 240 bei ELEMNT RIVAL zeigt die Leistungsdaten auf einem 64-Farben-LCD-Display an. Das Display ist an die Lichtverhältnisse anpassbar.
Simple to use
With the most intuitive user interface, ELEMNT devices have dramatically changed the way athletes interact with their devices. ELEMNT RIVAL is optimized to give runners a focused advantage.
JETZT KAUFENDIE ELEMNT ERFAHRUNG
Die kostenlose ELEMNT Companion-App verfügt über eine benutzerfreundliche Smartphone-Schnittstelle, die Sie durch die Einrichtung, das Erstellen eines Trainingsprofils, die Anpassung der Workoutanzeige und die Verknüpfung Ihrer ELEMNT RIVAL mit Ihren bevorzugten Fitness-Apps und drahtlosen Sensoren führt.
SMART-BENACHRICHTIGUNGEN
Mit ELEMNT RIVAL können Sie problemlos Freunde finden, die in Echtzeit trainieren. Und mit der Möglichkeit, E-Mails, Textnachrichten und Anrufe zu erhalten, bleiben Sie immer in Kontakt, selbst wenn Sie nicht erreichbar sind.
BESTE VERBINDUNG
Ob Sie reiten, laufen, schwimmen oder einfach trainieren möchten: ELEMNT RIVAL kann mit den beliebtesten Trainings-Apps und drahtlosen Sensoren verknüpft werden, um ein umfassendes Training zu bieten.
DRAHTLOSES SYNCHRONISIEREN
ELEMNT RIVAL bietet ein befreites Erlebnis, d. h. die Tage sind vorbei, wo man in Fummelarbeit Kabel zum Laptop verlegen musste, um die Workout-Daten zu synchronisieren oder die Software zu aktualisieren.
APP-BASIERTE TUTORIALS
Die Funktionen von ELEMNT RIVAL werden in Tutorials Schritt-für-Schritt erklärt. Die einfach erklärten Anweisungen begleiten Sie durch die einzigartigen Features von RIVAL, die sicherstellen, dass Sie das absolute Optimum aus Ihrer Uhr holen.
WORKOUT-EDITOR
Use Workout Editor on the ELEMNT Companion App to correct your segment timing on the Track Running or Triathlon profiles for variations between your watch and the official race results.
KICKR CONTROL
ELEMNT RIVAL ermöglicht Ihnen ein Bike-Training im Innenbereich. Durch die Verbindung mit den Smart Trainern von Wahoo KICKR behalten Sie die vollständige Kontrolle über den Smart Trainer, der vom Olympischen Goldmedaillengewinner und dem dreimaligen IRONMAN World Champion, Jan Frodeno, empfohlen wird.
SPEZIFIKATIONEN
TECHNISCHE DATEN | |
Abmessungen | 46,5 x 46,5 x 15,3 mm |
Display-Größe | 1,2 Zoll (30,4 mm) Durchmesser |
Display-Typ | Farbe |
Display-Auflösung | 240 x 240 |
Linsenmaterial | Gorilla® Glass |
Material Lünette | Keramik |
Material Gehäuse | Nylon-Polymer |
Material Band | Silikon |
Gurtlänge | 10 Zoll (25,4 cm) Für Handgelenkumfang 140 mm – 240 mm |
Gewicht | 53 g |
Akku | Wiederaufladbarer Lithium-Ionen-Akku |
Laufzeit Batterie | Smartwatch-Modus: 14 Tage GPS- oder HR-Modus: Bis zu 24 Stunden |
GPS-Funktionalität | Integriert |
Unterstützte Satelliten | GPS und GLONASS |
Wasserdurchlässigkeit | 5 ATM (wasserfest bis zu 50 Meter) |
Perfect View Zoom Knöpfe | Ja |
Umgebungslichtsensor | Ja |
KONNEKTIVITÄT | |
Drahtlose Verbindung | ANT+® und BLUETOOTH® |
Sensor-Kompatibilität | ANT+®, BLUETOOTH® und ANT+ FE-C |
Smartphone-Kompatibilität | iPhone und Android |
SENSOREN | |
Höhenmesser | Ja |
Kompass | Ja, GPS-basiert |
Gyroskop | Nein |
Beschleunigungsmesser | Ja |
Thermometer | Nein |
FUNKTIONEN UHR | |
Uhrzeit/Datum | Ja |
GPS-Zeitsynchronisation | Über die ELEMNT Begleiter-App |
Automatische Sommerzeit | Über die ELEMNT Begleiter-App |
Timer | Ja |
Stoppuhr | Ja |
INTELLIGENTE FUNKTIONEN | |
Einstellung Begleiter-App | Ja |
Individuell anpassbares Display | Ja |
Benachrichtigungen | Anruf, SMS, E-Mail, WhatsApp, Signal, Line, Telegram und WeChat |
Live Tracking | Über die ELEMNT Begleiter-App |
Steuert Smartphone-Musik | Ja (nur iOS) |
Automatischer Upload von Trainingseinheiten | Ja |
FUNKTIONEN ZUM AKTIVITÄTSTRACKING | |
Schrittzähler | Ja |
Kalorienverbrauch | Ja, aktive Kalorien |
Anzahl Stockwerke | Nein |
Distanz zurückgelegte Strecke | Ja |
Intensitätsminuten | Nein |
Trainingszeit | Ja |
Wöchentliche Strecke Schwimmen / Radfahren / Laufen | Ja |
Aktivitätsprofile | Indoor-Cycling (KICKR), Outdoor-Cycling, Outdoor-Laufen, Laufband, Laufbahn, Schwimmrunden (Pool), Schwimmen in offenen Gewässern, Krafttraining, Yoga |
FUNKTIONEN DER TRAININGSANALYSE | |
HR-Zonen | Ja |
HR-Kalorien | Ja |
Bluetooth- und ANT+ Broadcast-Metriken | Herzfrequenz, Pace und Schrittfrequenz |
GPS-Geschwindigkeit und -Entfernung | Ja |
Anpassbare Datenseiten | Ja |
Anpassbare Aktivitätsprofile | Ja |
Automatische Pause | Ja |
Automatische Runden | Ja |
Manuelle Runden | Ja |
Audioeingaben | Ja |
Endzeit | Ja |
Automatische Multisport-Aktivitäten | Ja |
Manuelle Multisport-Aktivitäten | Ja |
Schaltfläche Sperren | Ja |
Aktivitätsverlauf auf Uhr | Ja |
INTEGRATIONEN | |
Aktivitäts-Apps | Strava, TrainingPeaks |
Stationäre Trainer | Wahoo Smart Trainer und mit ANT+ und FE-C ausgestattete Trainer |
ELEMNT RIVAL RESSOURCEN
Schauen Sie sich diese Ressourcen an und erfahren Sie, wie Sie das Meiste aus Ihrem ELEMNT RIVAL und Workout machen!
What does proper running form look like? That depends on the individual, but there are principals to understand and aim for to ensure proper individual form. Learn what that means and how to apply it to your own training.
Do These Drills, Run Faster
How do you run faster? You may think, run more...but that is not always the answer and often leads to increased injury incident. Check out tips from our experts as to how to get faster in a safe and strategic way.
Ask the Experts: Tips for Running Through Tough Terrain
Branching out to more technical terrain often involves climbing, descending, and managing your footing, and is a much different experience than the path runs you’ve been knocking out. Learn more about how the type of terrain plays into your training, your level of fitness, and overall approach.
MEINE MOTIVATION | #MyRIVAL
Jeder hat einen Rivalen, der ihn antreibt. Finden Sie heraus, gegen welchen Rivalen die Wahoo Athleten kämpfen.
TEILEN SIE IHREN RIVALSEIEN SIE EIN WAHOOLIGAN
Markieren Sie #MyRIVAL oder @wahoofitnessofficial, um vorgestellt zu werden. Es gelten die allgemeinen Geschäftsbedingungen.
